mactable report on LMS3.2
raindrop18
objectives.  we have none cisco Access point and of course those not manged by CW. however there MAC-address are on mac table since they are attached to the switches. so instead of I am writing writing a script to pull all mactables from the switches, I am wondering if there is a report on CW for all mac table and if I can export them. thanks in advance for any suggestion.
Gaganjeet Chug
Level 4
Level 4
Probably you can try to get these Mac address from the Campus Manager > User Tracking > Reports > Report generator >
Hope it helps,
Gaganjeet
Gaganjeet Chug
Level 4
Level 4
Hope it helps,
Gaganjeet
