Managing Switch with Ansible Via SSH
sleepless swan
I am trying to manage a Catalyst 2960 switch with Ansible. The ansible controller is installed on a Linux VM. I haven't been able to SSH to the switch from the controller despite the service being enabled on the switch and the controller.
Connection:
- PC connected to switch with an ethernet cable. The port is configured with an IP in the same subnet as the VM.
Switch configuration
version 12.2
no service pad
hostname ansible
boot-start-marker
boot-end-marker
username mikko privilege 15 password 0 P@ssw0rd
username pocha privilege 15 secret 5 $1$OgQZ$HheCqdqxYg5az5KEaTrNV.
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip domain-name ansible.bh
spanning-tree mode pvst
vlan internal allocation policy ascending
ip ssh version 1
interface FastEthernet0/1
 switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
 ip address 192.168.7.17 255.255.255.0
 no ip route-cache
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
 login local
 transport input ssh
line vty 5 15
 login local
 transport input ssh
end
Whenever I try to ssh to the switch from the vm, I get a 'no route to host' error. Pinging gives a destination unreachable error.
I've tried to ssh to the switch using Putty, but the connection timed out.
Is it actually possible to manage the switch using Ansible with the current setup?
liviu.gheorghe
It's more than sure a problem related to VirtualBox or it's configuration. I presume that pinging the switch from the PC on which you installed VirtualBox is successful.
I think you would get more info on a Oracle/VirtualBox forum.
Regards, LG
*** Please Rate All Helpful Responses ***
19 Replies 19
liviu.gheorghe
Hello @sleepless swan ,
the switch configuration looks ok and you should be able to ssh into it, provided your PC has an IP from the 192.168.7.0/24 subnet and you have generated the rsa key needed for ssh.
You are trying to access the switch from a VM which is hosted on virtualisation platform, HyperV or ESXi for example. How is the virtualisation host connected to the switch? On interface FastEthernet 0/1?
How is the vSwitch from the virtualisation host configured? Trunk or single vlan?
Regards, LG
Hello @liviu.gheorghe
Indeed both the switch and VM are in the same subnet.
I'm using VirtualBox. The network adapter for the VM is set to NAT with the same subnet as the switch. The pc is connected to the fastethernet 0/1 port on the switch with an ethernet cable. I also have serial connection to the switch for direct configuration.
Is it possible that I should choose the bridged network adapter for the VM instead? I still haven't tested that yet because it would require a VM reboot and it would take quite sometime due to the tools running on the VM.
I see no reason for this not to work here.
  • Double-check IP addresses: Ensure the VM and switch are configured with valid IP addresses in the same subnet.
  • Check subnet mask: Confirm both devices have the same subnet mask (e.g., 255.255.255.0).
  • Verify default gateway: Make sure the VM has the switch's IP address set as its default gateway.
  • Check the routing table on the PC connected
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
is there a specific reason you are using SSH v1 ? Can you ping 192.168.7.17 from the Ansible controller ?
I'm assuming it wouldn't matter if it's v1 since it's just a testing environment? Unfortunately, I'm unable to ping from the Ansible controller which of course means I can't SSH to it.
Can you share the output of the netstat -nr command from the linux vm?
Regards, LG
Please find the requested output
And also show arp from the switch and arp -an from the linux vm.
Regards, LG
liviu.gheorghe
Also show cdp neighbor from the switch.
You have no communication between your switch and the linux vm - no Mac address of the vm or switch in each others arp table.
Your linux VM is hosted on what virtualisation platform? Vmware, HyperV or something else?
Regards, LG
There are no cdp neighbors in the output. I'm using VirtualBox
Ok. Then I believe there is a problem with the networking configuration on your VirtualBox. Can you share a screenshot of the networking configuration for the linux vm?
Regards, LG
These are the NAT adapter settings
I would change the settings for the first adapter - Attached to: Bridged Adapter.
This way you are sure that your vm is in the same vlan as the switch management vlan. I presume that the PC you are running VirtualBox on is attached to the switch on the first port - interface FastEthernet0/1.
Regards, LG
