mgt tool
dave dave
hi! is there any tool out there that can keep monitor traffic of different type? eg, http, ftp,  and etc? Is there a tool that can differentiate different  port or traffic type?
Marvin Rhoads
Sure there are lots.
Mostly they depend on your network device(s) being able to keep track of the information and the tools just query the devices and present for you in a useful way.
Common in Cisco networks is the use of NetFlow (technology) for this purpose. Once can use a tool like ntop (open source), Solarwinds Netflow Traffic Analyzer (free for real time few device view, licensed for archiving and more devices), ManageEngine's Netflow Analyzer (free 30-day demo, licensed for long term use), etc. You typically need a router or high end core switch that supports NetFlow - small layer 3 switches and layer 2 devices will not.
Some other devices (e.g., load balancers like F5 LTM and Citrix Netscaler) also instrument things like http req/sec etc. and can be queried using SNMP management tools (such as Cacti - open source or Solarwinds Orion NPM - licensed) to display utilization.
NetFlow is the best technology to get information on traffic based on  application, port, protocol, IP Address, etc. There are a lot of free  tools you can make use of or go for a licensed tool as per your  requirements.
You may find the below link useful to select a free tool.
http://www.networkmanagementsoftware.com/5-free-netflow-analyzer-tools-for-windows
From the list, ManageEngine, Solarwinds and Plixer are market leaders with both free and licensed versions available.  ManageEngine and Plixer, both support stand alone NetFlow installations  whereas Solarwinds requires a base software for installing NetFlow  monitoring module. Full fledged Linux version is available with ManageEngine.
Don Thomas Jacob
www.netflowanalyzer.com
NOTE: Please rate posts and close questions if your query has been answered
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
