Mixed Platform for Switches and Wireless Access Points
techno.it
Beginner
Beginner
We're currently facing some challenges with our large-scale mixed deployment of Switches and Wireless Access Points from Cisco and Aruba, and I'm hoping to gather some valuable insights and suggestions from the community.
Our network infrastructure consists of both Cisco and Aruba devices, and the main difficulties we're encountering are as follows:
Different UI: Managing the network becomes a bit of a hassle due to the varying UIs. Aruba uses Airwave, while Cisco relies on DNAC. This disparity in UIs makes it time-consuming for us to navigate and configure both platforms efficiently.
Lack of Central Management and Network Analytics: We're struggling with the absence of a centralized solution for managing and monitoring devices across both platforms. It would be ideal to have a single management system that allows us to seamlessly control and monitor both Cisco and Aruba devices
Single NAC Solution: We're in need of a Network Access Control (NAC) solution that is compatible with both Cisco and Aruba devices. This NAC solution should be fully functional and comply with standards such as RADIUS and TACACS+. Specifically, we're looking for features like MAC profiling for dynamic MAC registration, BYOD portals, and guest portals. Additionally, it should support both wired and wireless 802.1x authentication and provide administrative authentication for Aruba and Cisco devices.
Open to any suggestions or recommendations that can help us address these challenges.
For Radius and Tacacs you can use ISE for both Cisco and Aruba.
.https://community.cisco.com/t5/security-knowledge-base/ise-third-party-nad-profiles-and-configs/ta-p/3648719
Management is hard to believe there will be a single solution for both. If were talkning about monitoring, I would say you can use an open source like Zabbix but Management is more complicate. You can take a look in Itenttial solution and maybe do a PoC to make sure it is what you are looking for.
