Monitor data usage for Local pool on 7609
Sohaib Atta
Is there any way to monitor and plot graphs against the data usage for each local pool configured on Cisco 7609.
I have a CISCO 7609 that is acting as RAS for PPPoE Customers and have mulitple local pools (/24) configured on it. What is requried is a graph that shows data usage of each pool separately ( I can plot usage against each IP but that is not requried here, I need data usage (MRTG) for each complete local pool).
Would appreciate if someone can suggest a solution to it.
paolo bevilacqua
Wrong forum, post in "network management". You can move your posting using the actions panel on the right.
