Monitoring FTD upgrades with FDM or CLI
swaite2121
Hello
Is there a way to monitor the progress of a FTD upgrade with the device being managed by FDM? I am currently testing a Firepower 2130.
balaji.bandi
i am not familiar with FDM, since most of the case i used FMC for upgrade,
if you looking to upgrade from command level below guide help and process  you can monitor.
https://community.cisco.com/t5/security-documents/firepower-threat-defense-ftd-code-upgrade-manually/ta-p/3956949
BB
Thanks for the link. Seems like there would be another way but this does get the job done.
Glad it helpfull let us know how your upgrade goes.
BB
