03-12-2020 06:30 AM
Hello
Is there a way to monitor the progress of a FTD upgrade with the device being managed by FDM? I am currently testing a Firepower 2130.
03-12-2020 06:33 AM
i am not familiar with FDM, since most of the case i used FMC for upgrade,
if you looking to upgrade from command level below guide help and process you can monitor.
03-12-2020 06:58 AM
Thanks for the link. Seems like there would be another way but this does get the job done.
03-12-2020 08:27 AM
Glad it helpfull let us know how your upgrade goes.
