My 5k NTP is not syncing with Catalyst 9500...
George-Sl
My catalyst 9500 is the master NTP, and my 5k doesn't sync with it...
clock protocol ntp
ntp server x.x.x.x
I found the error, Nexus can't sync with 9500, I changed it to a windows server 2016 and it works
6 Replies 6
Mark Elsen
 https://www.cisco.com/c/en/us/support/docs/ip/network-time-protocol-ntp/116161-trouble-ntp-00.html
 M.
Cristian Matei
   Depending on the initial time difference, it may take more than instant synchronisation. Post the output of "show ntp status" and "show ntp associations detail" from IOS and "show ntp peer-status" from Nexus.
Cristian Matei.
5KMDF# show ntp peer-status
Total peers : 1
* - selected for sync, + - peer mode(active),
- - peer mode(passive), = - polled in client mode
remote local st poll reach delay vrf
=10.x.x.2 0.0.0.0 8 16 4 2.25627 default
5KMDF#
5KMDF# show ntp status
Distribution : Disabled
Last operational state: Commit operation failed
5KMDF#
5KMDF# show ntp association
% Invalid command at '^' marker.
5KMDF#
C9500 is in ntp master mode
ntp server time.windows.com
ntp server time.nist.gov
 - Did you enable NTP on the 5k with "feature ntp" ?
  M.
ntp is enabled
