ā04-11-2023 03:02 AM - edited ā04-11-2023 03:03 AM
Ive been searching for the config register entry of a nexus N9K-C93180YC-EX version 10.2(4) and i have failed to find it. Ive done a pipe on show tech for confreg and configuration register but output show no entries. Show version also has no configuration registration value.
The issue im having is the baud rate on my console and vty is locked to 115200 and im not able to amend. I suspect after the weekend upgrade to this version altered the config register but i need to confirm this.
In summary where is it? How can i find it?
ā04-11-2023 03:12 AM
If you do:
switch# line console switch(config-console)#
switch(config-console)# speed 57600
The device stay in 115200 ?
ā04-11-2023 04:06 AM
Yes. If I change it to any speed, the baud config on console remains. Hence why I think its config register.
ā04-11-2023 03:51 AM
ā04-11-2023 04:53 AM
Thanks for the response. Dont necessarily want to do password recovery if its not required. I could just change the confreg if this needs to be done resolve the issue. There is no command to see configuration register in the url.
ā04-11-2023 05:11 AM - edited ā04-11-2023 05:11 AM
Yes but as I know the NSK use modes different than SW and Router
the new mode called loader
from there you can config boot <image of NX-OS>
that why I share above, check again link.
thanks
MHM
