03-31-2011 08:22 AM
04-01-2011 12:48 AM
What seems to be the problem? Here is the release notes for the latest version and instructions for the upgrade.
Release notes:
Install and upgrade:
04-01-2011 08:45 AM
Thanks for the reply however we already have the 1.6.01 patch. It appears if your server is 32-bit you can still have the out of memory problem. We had to reduce concurrent tasks down to 40% below default to get NCM to work without spontaneous restarts.
06-13-2011 06:39 AM
We too are on NCM 1.6 and have memory issues. However, our server is 64-bit. I cannot yet find anything about where to increase the internal allocation. We have 16BG on our host, yet NCM seems dead set on only using a fraction of it.
I disabled the memory event monitor because it was becoming far too annoying. But this is what I would see constantly:
Monitor: MemoryMonitor
Description: Monitor for checking the memory available to the system.
New Status: Error
New Result: Only 43 MB free. It is lower than both "Warning Threshold for Free RAM" settings (64MB and 15%). No task will run until this issue is resolved.
Previous Status: Okay
Previous Result: 153 MB free
There has to be a way to give it more resources. I'd like to increase the number of concurrent tasks, but doing so causes the system to completely choke on itself.
