NEED Network Performance Test Tools??
mmozanen
Level 2
Level 2
Dear,
I always assigned the task for evaluating a network products, like cisco,3com,nortel, hp and etc.
And want to know what tools should I use to compare them like , speed, performance, etc, in a lab that I can set.
Is there any specific software you recommend.
with regrds.
sbilgi
Level 11
Level 11
Try using the Ethereal application to analyse the traffic in an ethernet .
Dear,
Thanks alot.
regards
maybe you can try Packetizer too.
dave.keith
Level 5
Level 5
Have a look at NetIQs freeware product QCHECK. Here is a link to a page that reviews QCHECK briefly. It also has links to the download page at NetIQ.
http://www.practicallynetworked.com/reviews/qcheck.htm
Dave
