Showing results forĀ
Search instead forĀ
Did you mean:Ā
Netflow doesnt work on SVI interface.
mathewmnu2
Hey all,
Looks like my netflow configured on SVI does not work- however physical interface works without any problem. For example as per below config GigabitEthernet0/0/1 works but GigabitEthernet0/1/0 does not work which is part of an SVI. Not sure if i have to add any config on flow record ?
flow record netflow-sites
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
match flow sampler
match application name account-on-resolution
collect routing source as
collect routing destination as
collect routing next-hop address ipv4
collect ipv4 source mask
collect ipv4 destination mask
collect transport tcp flags
collect interface output
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow exporter netflow
destination x.x.x.x
source Loopback200
transport udp 2055
option application-table
flow monitor netflow-nbar
exporter netflow
interface Loopback200
ip flow monitor netflow-nbar input
ip flow monitor netflow-nbar output
ip address x.x.x.x 255.255.255.255
interface GigabitEthernet0/0/1
ip address x.x.x.x 255.255.255.224
interface Vlan30
ip vrf forwarding INTERNET
interface GigabitEthernet0/1/0
switchport access vlan 30
no cdp enable
thanks
Matthew
9 Replies 9
balaji.bandi
what is the Model of the device and what IOS code running - so we know the environment what we are trying to troubleshooting here.
is this typo or VLAN30 have IP address ? (bear in mind VLAN 30 in VRF ?)
May be try example below : if the IOS code support that features.
match routing vrf input
BB
Hello
NAME: "Chassis", DESCR: "Cisco ISR4321 Chassis"
isr4300-universalk9.17.03.05.SPA.bin"
is the vlan30 has ip address configured.
thanks
Mathew
Getting below when trying to add the command suggested
mathewmnu2
Applied command match routing vrf input to exporter - however it didnt make any difference.
#show ip cache flow
IP packet size distribution (0 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608
IP Flow Switching Cache, 0 bytes
0 active, 0 inactive, 0 added
0 ager polls, 0 flow alloc failures
Active flows timeout in 30 minutes
Inactive flows timeout in 15 seconds
last clearing of statistics never
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
SrcIf SrcIPaddress DstIf DstIPaddress Pr SrcP DstP Pkts
match ipv4  version <- add this under flow record
And remove natch routing vrf input from export
Check if not work share last config you use
MHM
sure - will try and get back.
fyi - netflow works fine on other interfaces - it is on interfaces with vrf config it does not work.
thanks
Mathew
Goodluck friend
MHM
changed as suggested - however no difference
match ipv4 tos
match ipv4 protocol
match flow sampler
match ipv4 version
show ip cache flow
