Netflow not working
Bart Mars
Hi there,
I've got a rather odd situation going here. In our company we use NetFlow to measure network traffic. Some of our NetFlow devices have gotten an upgrade and stopped working. When I look at the configuration, I see:
ip flow-cache timeout active 1
ip flow-export source Vlan3
ip flow-export version 9
ip flow-export destination 172.29.1.12 9996
interface GigabitEthernet0/48
switchport access vlan 3
switchport mode access
switchport nonegotiate
ip flow ingress
ip flow egress
logging event link-status
speed 100
duplex full
mls qos trust dscp
no snmp trap link-status
no cdp enable
spanning-tree portfast
end
I can confirm that the NetFlow Analyzer is working, as some of the network devices are still sending their NetFlow information. VLAN3 is where the outside IP is configured. Interface G0/48 is member of that VLAN. The switch that I'm troubleshooting:
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C3560G-48PS     15.0(1)SE3            C3560-IPBASEK9-M
Flow export v9 is enabled for main cache
  Export source and destination details :
  VRF ID : Default
    Source(1)       192.168.100.81 (Vlan3)
    Destination(1)  172.29.1.12 (9996)
  Version 9 flow records
  0 flows exported in 0 udp datagrams
  0 flows failed due to lack of export packet
  0 export packets were sent up to process level
Vlan3
  ip route-cache flow
  ip flow ingress
GigabitEthernet0/48
  ip flow ingress
  ip flow egress
I'm kinda unsure what goes wrong here. I believe to have configured everything right.
Can somebody help me?
Rolf Fischer
Level 9
Level 9
Hello Bart,
unfortunately NetFlow is not supported on the c3560v1 plattform.
You can find the "ip flow ..." commands in the unsupported commands section of the command references.
I'm interested in NetFlow too and wonder if your configuration has worked before you updated the IOS because (apart from the fact that it's not supported) you applied all the commands for measuing at Layer 2? What IOS did you use before?
Best regards
Rolf
Rolf Fischer
Level 9
Level 9
Hello Bart,
Best regards
Rolf
Hi Rolf,
I searched across the Cisco site and didn't pay too much attention of the different types of 3560 switches. Because I saw the commands in IOS, I immediately thought that they would work. (Assumptions...)
Well,  I did some research and it turns out that what I said before, wasn't  completely true. According to my collegues, all switches that have this  problem, have been replaced old Cisco 2811 routers last year. So that's  why they said it did work before.
