Nexus 9K Interface 1/11 - 1/60 stay Orange! [Amber]
TheGoob
Level 4
Level 4
Hi, so for the life of me I can NOT GET THESE Interfaces to not be orange!!!! Oddly enough, 61 - 96 are Off but turn green when I plug into.
!Command: show running-config
!Running configuration last done at: Sat Feb 10 04:16:35 2024
!Time: Sat Feb 10 04:16:40 2024
version 9.3(10) Bios:version 07.69
switchname NexusHOM
vdc NexusHOM id 1
  limit-resource vlan minimum 16 maximum 4094
  limit-resource vrf minimum 2 maximum 4096
  limit-resource port-channel minimum 0 maximum 256
  limit-resource u4route-mem minimum 248 maximum 248
  limit-resource u6route-mem minimum 96 maximum 96
  limit-resource m4route-mem minimum 58 maximum 58
  limit-resource m6route-mem minimum 8 maximum 8
feature telnet
feature interface-vlan
feature dhcp
no password strength-check
username admin password 5 $5$IMMKLC$CupMwUYLPCuvsts8FDGOoTLNHoAISOcbD1.lqjo1NM5
 role network-admin
ip domain-lookup
copp profile strict
snmp-server user admin network-admin auth md5 215172AA8DF3EA6F144B141758F7652620
98 priv 043E7EB18BE4DB7B055E164057F66E217A95 localizedV2key
ip route 0.0.0.0/0 192.168.8.1
vlan 1
service dhcp
ip dhcp relay
ipv6 dhcp relay
vrf context management
interface Vlan1
  no shutdown
  ip address 192.168.5.1/24
  ip dhcp relay address 192.168.5.1
interface Vlan2
  no shutdown
  ip address 192.168.1.1/24
  ip dhcp relay address 192.168.1.1
interface Vlan3
  no shutdown
  ip address 192.168.2.1/24
  ip dhcp relay address 192.168.2.1
interface Vlan4
  no shutdown
  ip address 192.168.3.1/24
  ip dhcp relay address 192.168.3.1
interface Vlan5
  no shutdown
  ip address 192.168.4.1/24
  ip dhcp relay address 192.168.4.1
interface Vlan6
  no shutdown
  ip address 192.168.6.1/24
  ip dhcp relay address 192.168.6.1
interface Ethernet1/1
  no switchport
  ip address 192.168.8.2/24
  no shutdown
interface Ethernet1/2
  spanning-tree port type normal
interface Ethernet1/3
interface Ethernet1/4
interface Ethernet1/5
interface Ethernet1/6
interface Ethernet1/7
interface Ethernet1/8
interface Ethernet1/9
interface Ethernet1/10
interface Ethernet1/11
  switchport access vlan 2
interface Ethernet1/12
interface Ethernet1/13
interface Ethernet1/14
interface Ethernet1/15
interface Ethernet1/16
interface Ethernet1/17
interface Ethernet1/18
interface Ethernet1/19
interface Ethernet1/20
interface Ethernet1/21
  switchport access vlan 3
interface Ethernet1/22
interface Ethernet1/23
interface Ethernet1/24
interface Ethernet1/25
interface Ethernet1/26
interface Ethernet1/27
interface Ethernet1/28
interface Ethernet1/29
interface Ethernet1/30
interface Ethernet1/31
  switchport access vlan 4
interface Ethernet1/32
interface Ethernet1/33
interface Ethernet1/34
interface Ethernet1/35
interface Ethernet1/36
interface Ethernet1/37
interface Ethernet1/38
interface Ethernet1/39
interface Ethernet1/40
interface Ethernet1/41
  switchport access vlan 5
interface Ethernet1/42
interface Ethernet1/43
interface Ethernet1/44
interface Ethernet1/45
interface Ethernet1/46
interface Ethernet1/47
interface Ethernet1/48
interface Ethernet1/49
  no switchport
  ip address 192.168.12.2/24
  no shutdown
interface Ethernet1/50
  switchport access vlan 6
interface Ethernet1/51
interface Ethernet1/52
interface Ethernet1/53
interface Ethernet1/54
interface Ethernet1/55
interface Ethernet1/56
interface Ethernet1/57
interface Ethernet1/58
interface Ethernet1/59
interface Ethernet1/60
interface Ethernet1/61
interface Ethernet1/62
interface Ethernet1/63
interface Ethernet1/64
interface Ethernet1/65
interface Ethernet1/66
interface Ethernet1/67
interface Ethernet1/68
interface Ethernet1/69
interface Ethernet1/70
interface Ethernet1/71
interface Ethernet1/72
interface Ethernet1/73
interface Ethernet1/74
interface Ethernet1/75
interface Ethernet1/76
interface Ethernet1/77
interface Ethernet1/78
interface Ethernet1/79
interface Ethernet1/80
interface Ethernet1/81
interface Ethernet1/82
interface Ethernet1/83
interface Ethernet1/84
interface Ethernet1/85
interface Ethernet1/86
interface Ethernet1/87
interface Ethernet1/88
interface Ethernet1/89
interface Ethernet1/90
interface Ethernet1/91
interface Ethernet1/92
interface Ethernet1/93
interface Ethernet1/94
interface Ethernet1/95
interface Ethernet1/96
interface Ethernet1/97
interface Ethernet1/98
interface Ethernet1/99
interface Ethernet1/100
interface Ethernet1/101
interface Ethernet1/102
interface mgmt0
  vrf member management
  ip address 192.168.15.1/24
icam monitor scale
line console
line vty
boot nxos bootflash:/nxos.9.3.10.bin
liviu.gheorghe
Hello @TheGoob ,
you created the SVI for vlan 2-6, but you should create the vlans as well: vlan 2-6
Regards, LG
*** Please Rate All Helpful Responses ***
5 Replies 5
marce1000
               - Check logs on the nexus and or when trying to use these ports (too) ,
 M.
liviu.gheorghe
Hello @TheGoob ,
Regards, LG
Thank you all, but this is what my issue was.
/facepalm
balaji.bandi
Default port behavior is Layer 3 - if this is host use guide lines as below :
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/interfaces/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_chapter_011.html
post below information also for us to suggest best :
show vlan
show interface capabilities
show interface switchport
show interface eth 1/11
BB
what happens if you default one of the interfaces, e.g.:
NexusHOM#conf t
NexusHOM(config)#default interface ethernet1/11
Does the LED color change ?
