02-08-2024 05:13 PM
It says I changed it, but every reboot does not take it. Followed https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/password_recovery/b_nx_os_pwr/nx_os_pw.html
02-08-2024 05:57 PM - edited 02-08-2024 06:00 PM
bump
02-09-2024 03:35 AM
the procedure you are following looks straight forward, not sure why it does not work. Try the one linked below:
02-09-2024 08:54 AM
That is actually the one I followed as well. It’s weird, both times it did not take password. I think it’s the console connection. Like even on my SMB Switches, I’ll hit keystrokes 1 at a time, won’t work.. I go to gui and works. It’s like when I type console it doesn’t do correct keys. Anyway, I factory-reset the whole thing, wishing I did not cause now I forgot all I had done in it, but whatever.
