Nexus 9K, resetting password is not working.
TheGoob
TheGoob
bump
the procedure you are following looks straight forward, not sure why it does not work. Try the one linked below:
https://zed-network.fr/?p=265
TheGoob
That is actually the one I followed as well. It’s weird, both times it did not take password. I think it’s the console connection. Like even on my SMB Switches, I’ll hit keystrokes 1 at a time, won’t work.. I go to gui and works. It’s like when I type console it doesn’t do correct keys. Anyway, I factory-reset the whole thing, wishing I did not cause now I forgot all I had done in it, but whatever.
