No MIB for Nexus port config characteristics?
ww9rivers
I looked through all the MIBs supported on Nexus 7K and could not find an object that would tell me if an Ethernet interface is configured to allow auto-negotiation or not.
So I did a test: on the NX-OS command line, I did an snmpwalk starting from "iso", saved the result to file-1.
Then I configured one interface, say Eth2/32, from speed "auto" to 10G. Ran the above command again and saved the result to file-2.
After that, I extracted all the lines in the two files about interface 2/32 using its ifIndex, diff'ed the results and found no difference except for in/out traffic counters.
Does this mean that NX-OS has no SNMP support for stuff like that?
Have I missed something in my experiement?
Is this an indication of Cisco's moving from SNMP to XML based device management?
Details: I run SNMP v2c. The Nexus box is:
Software
  BIOS:      version 3.22.0
  kickstart: version 5.1(4)
  system:    version 5.1(4)
  BIOS compile time:       02/20/10
  kickstart image file is: bootflash:///n7000-s1-kickstart.5.1.4.bin
  kickstart compile time:  12/25/2020 12:00:00 [06/28/2011 23:28:40]
  system image file is:    bootflash:///n7000-s1-dk9.5.1.4.bin
  system compile time:     5/31/2011 18:00:00 [06/29/2011 00:19:13]
Thanks and regards,
Wei Wang
Yeah, but those didn't give me “a-half” or “a-full” like one would get on the IOS CLI, only “half, full, disagree, or auto”. IIRC, the cat6k's I dealt with didn't support MAU-MIB, nor a third candidate MIB I came across--ETHERLIKE-MIB.
yjdabear
You mean it's possible to get auto- vs non-auto from SNMP OIDs for non-Nexus, such as IOS)? I couldn't find any when I tried to come up with a similar report for a bunch of cat6k's.
Cat-6K's support the CISCO-STACK-MIB, which has "CISCO-STACK-MIB::portAdminSpeed".
I haven't looked at VSS -- The Cat-6K MIB page has a note saying "Not supported in VSS mode" next to the CISCO-STACK-MIB. Maybe you will have to look at "MAU-MIB::ifMauAutoNegAdminStatus" there.
