Other vendor devices using Prime Infrasctructure 2.0
aparada14
What level of monitoring can I have with other vendor devices using Prime Infrasctructure 2.0?
AFROJ AHMAD
Third-Party Support in PI :
• Third-party support permits the discovery and monitoring of non-Cisco switches that support RFC 1213 and wireless controllers/access points from Aruba Networks.
check the below link::
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/prime-infrastructure/data_sheet_c78-729088.html
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
jcockburn
If the device supports SNMP it can check basic reachablility....
Reachable can be checked via SNMP , yes
Afroz
Saurav Lodh
Level 7
Level 7
https://supportforums.cisco.com/discussion/12198716/monitoring-non-cisco-device-using-cisco-prime-infrastructure-20
