Physical vs Logical Network design
burhaans28
Hi, guys
This is my physical network design i did it like this I dont know its a right way or not I used Three tier architecture.
So how to convert this physical into logical network design
Kind Regards
10 Replies 10
M02@rt37
Hello @burhaans28
Core layer are which unit ? Nexus ? Catalyst?
Develop an IP addressing scheme for your logical design. Consider subnets for different segments of your network. This includes addressing for core, distribution, and access layers.
Choose the routing and switching protocols that will be used within each layer. For example, OSPF or BGP for routing in the core, VLANs and STP at the access layer, etc...
Incorporate logical redundancy and high availability mechanisms. This may include redundant links, HSRP/VRRP for gateway redundancy, and routing protocols with fast convergence.
As concerned WAN side, check where NAT is active, add BGP peer with ISP router and mark how WAN traffic is handled....ISP 1 as primary ? Etc...
Best regards
So as for my physical design this one is okay i need to do logical
I am using cisco 9500 switch at the core layers
so i will give the ip on the same design
and how can i give the ip address scheme
Ok @burhaans28
C9500 play the role of core and distri.
Fw acting as Gateway for each vlan ? Core acting Gateway with vip hsrp ? Consider this for you logical topology.
Best regards
very well, Let me do the logical design  and post it here pls let me know if it is correct or not
Sure @burhaans28.
Best regards
I disagree.
If I was to strictly follow the design, my core switch would be a 9600.  The 9500 will be my distro and my access layer will depend on the design, use, size of each rack and budget.  My access layer could be a 9400, 9300, 9200 or even a Catalyst 1000.
No need distrubte layer
You can merge core and distribute layer in one.
MHM
okay but the diagram that i have is that way the physical network design we do or my diagram is wrong for physical network design
If we connect many campus we need Core to send packet inbetween
Here you have only one so why core.
We dont need it.
MHM
Okay I got that part and how can i give the logical design
and ip addressing scheme like supoose i have 8 vlan and 4 vlan has 2000 users and 4 vlan has 1000 users
