PI 1.2 High cpu on devices when snmp poll
javier.pobeda
        Hi all,
I´m setting up our new PI 1.2. After we discovered devices and successfully added, PI started to hit CPU devices every 10 minutes, when SNMP poll runs.
CPU utilization for five seconds: 99%/11%; one minute: 29%; five minutes: 17%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
272    23536856     1524766      15436 86.62% 17.07%  5.06%   0 SNMP ENGINE
Is there any custom field to prevent this kind of snmp abuse on our devices?
If you need any further information, please let me know.
talmadari
Hi Javier,
Did you manage to find a solution to this issue?
i'm facing the same problem with PI1.2 but i noticed it's releated to the router IOS image, it occurs only on 15.0(1)M8 where on 12.2(24)T4 it won't.
i wonder...
Hi there,
No, I didn´t!
HOSTNAME#sh processes cpu sorted | exc 0.00
CPU utilization for five seconds: 99%/29%; one minute: 50%; five minutes: 27%
285    97063956     5010425      19372 69.60% 31.80%  9.11%   0 SNMP ENGINE
136         324         196       1653  0.22%  0.29%  0.07% 388 SSH Process
129    15444024   112760917        136  0.15%  0.08%  0.08%   0 IP Input
248       67600      579359        116  0.15%  0.08%  0.08%   0 FNF Cache Ager P
  83      660796    78806711          8  0.15%  0.13%  0.15%   0 Netclock Backgro
  65      860544    19708629         43  0.07%  0.09%  0.09%   0 Per-Second Jobs
HOSTNAME#sh stacks 285
Process 285:  SNMP ENGINE
  Stack segment 0x31029AE4 - 0x3102C9C4
  FP: 0x3102C8F0, RA: 0x23865C98
  FP: 0x3102C918, RA: 0x2361E354
  FP: 0x3102C988, RA: 0x237FC764
  FP: 0x3102C9A0, RA: 0x237FC748
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M1, RELEASE SOFTWARE (fc1)
I will look for a router with IOS 12.something and I will perform some test. But for me, It´s something related to IP or routing table mib.
I´ll keep you aware.
Well, I finally found a router with 12.something IOS and It´s working fine by now.
What I did on the router with IOS 15 was to make an snmp view like this:
snmp-server view myview iso included
snmp-server view myview at excluded
snmp-server view myview ip.22 excluded
snmp-server community xxxxxx view myview RO SNMP-ACL
I took this from a "similar bug"
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCta43825&from=summary
It seems to be some bug related to ARP table entry or something like that..
Ideas?
