PI 2.0 Altering config when adding device.
graham.harper
Hi, We have just stood up a PI 2.0 install noticed something strange when checking the configs, In the configuration archives saw a load of devices with out of sync devices (mismatched running and start up configs.)
On checking seemed the "snmp-server location xxxx"  config was missing from the running but ok in the start up.
So I tested it on a device I knew had matching start up and running and the snmp-server location in it.
Seemed that once Prime had Synced the new device the command was removed.
Anyone else come accross this "feature"?
pgustafson8235
Level 4
Level 4
We also saw this issue and was told -
you are hitting bug CSCuj09556 , please find in the below link the bug details :
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCuj09556
as a workaround , please perform the following :
Add/sync the device with RO community (to read the system location) and after that, change the community in PI to RW with following snmp view:
snmp-server view SYS_exclude system.6.0 excluded
snmp-server view SYS_exclude iso included
snmp-server community view SYS_exclude RW
pgustafson8235
Level 4
Level 4
Thanks for that!
