Port status on Cisc 9300 when Etherchannel
giangle
Hi all
Last week, I configured EtherChannel port between 2 Cisco 9300, network diagram:
       Cisco 9300 (Office)=====Leaseline ======= Cicso 9300 (DataCenter ISP)
In 9300 (Office):
Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.6.5
Group Port-channel Protocol Ports
93 Po93(SU) LACP Gi1/0/1(P) Gi1/0/8(P)
CoreSW_TV#show interfaces g1/0/8 stat
GigabitEthernet1/0/8
Switching path Pkts In Chars In Pkts Out Chars Out
Processor 0 0 28075 3281940
Route cache 0 0 0 0
Distributed cache 0 0 0 0
Total 0 0 28075 3281940
CoreSW_TV#show interfaces g1/0/1 stat
GigabitEthernet1/0/1
Processor 0 0 2393477 277463956
Route cache 0 0 0 0
Total 0 0 2393477 277463956
But led status in port G1/0/8 is amber. It's not green. Please explain and help me to fix this issue.
Giang Le
change this one as below and let us know, how it goes.
interface GigabitEthernet1/0/1
switchport access vlan 93
switchport mode access
channel-group 93 mode active
end
Office_SW#show run int g1/0/8
Building configuration...
Current configuration : 120 bytes
interface GigabitEthernet1/0/8
end
BB
10 Replies 10
marce1000
 - Issue the command show logging when the port get's connected ; check if there is more info.
   M.
Hi marce1000.
This is a log from log server in Cisco 9300 (office)
%ETC-5-L3DONTBNDL2: Gi1/0/8 suspended: LACP currently not enabled on the remote port.
Can you post both the side configuration related to that port-channel?
above errors show far end not configured.
BB
This is my configure at far end:
93 Po93(SU) LACP Gi1/0/6(P) Gi2/0/6(P)
In far end, we use stack 9300 and use G1/0/6 for Stack-SW-01, G2/0/6 for Stack-SW-02. connection from Data Center to Office via ISP lease line.
Giang Le
That is not a configuration that is the output of EtherChannel output.
post below information : (given example, post both the side).
show run interface gi 1/0/1
show run interface gi 1/0/8
show run inter port-channel 93
show run interface gi 1/0/6
show run interface gi 2/0/6
BB
Hi balaji.bandi.
I sent you my configre in both side:
Data Center ISP:
CoreSW#show run int g1/0/6
Current configuration : 158 bytes
interface GigabitEthernet1/0/6
end
CoreSW#show run int g2/0/6
interface GigabitEthernet2/0/6
end
CoreSW#show run int port-channel 93
Current configuration : 83 bytes
interface Port-channel93
end
Office:
Office_SW#show run int g1/0/1
Current configuration : 150 bytes
channel-group 93 mode passive
end
end
Office_SW#show run int port-channel 93
end
Output result:
Office:
DataCenter ISP:
14 Po14(SU) LACP Gi1/0/21(P) Gi2/0/21(P)
15 Po15(SU) LACP Gi1/0/22(P) Gi2/0/22(P)
REgards
Giang
end
end
BB
Hi balaji.bandi,
It worked with your configuration.
I have a question. At local office, I was running with Active/Passive configuration. But between office - Data Center ISP, this mode didn't work. I wonder what's difference on this except Active sent out LACP packet.
Giang Le
LACP always Active initiate the connection and Passive listens ( passive do not have capabilities to initiate)
If both set ACTIVE, anyone can initiate the connection. no need to wait for a partner to initiate the connection, your side shut and unshut should form the port-channel.
Maybe your Case Passive and Active should work. ( if you like to try After Passive side up and running, Active side shut and un shut to form the port-channel).
But i would prefer to have Active/Active, so you have both the side control.
make sense?
BB
OK, clearly. Thanks so much
Ticket can solve.
