Prime hardware appliance setup through lan
adeebtaqui
Level 4
Level 4
Kindly advise how to do installation and initial setup of prime gen 3 appliance PI-UCSM5-APL-K9 using lan port connected from my laptop instead of using kvm or seperate keyboard monitor so i can access the gui for further configuration
balaji.bandi
Get the Latest PI 3.10 and install and configure it as mentioned below guide - initial setup.
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-10/quick_start/guide/cisco_prime_infrastructure_3_10_quick_start_guide.html#task_1070814
BB
HI @balaji.bandi
We already have Prime appliance which comes with software pre-installed.
Need advise on how to access setup console directly from lan ports or mgmt lan port using my laptop like how we access switches instead of using a separate monitor and keyboard or KVM
For the console, you need to DB connector -
what information is missing from the above document,
check the section :
Set Up Prime Infrastructure on a Virtual Machine or Physical Appliance
Once you have setup the basic config :
you can use below guide for GUI :
https://www.youtube.com/watch?v=PZQBYfI_Cq0
BB
