Prime Infrastructure 2.1 NCS Physical Appliance as a Syslog Server
aparada14
I have a PI 2.1 NCS Physical Appliance and a client want it as a syslog server too, routers and switches have been configured to send the log to PI but I can't see anything in Operate > Alarms & Events; click Syslogs. Anybody knows what could be the issue or if it's necesary enable a check box.
Thanks.
6 Replies 6
AFROJ AHMAD
Hi ,
So far PI can only show Severity 0 ,1 and 2 syslogs under Operate > Alarms & Events >syslogs
If you are not able to see them also then try to restrat the PI services (ncs stop and ncs start ) and check the issue again
Thanks-
Afroz
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Marvin Rhoads
On Prime Infrastructure (at least up to and including Release 2.1), parsing and the ability to view syslog messages lower than level 2 requires modification of a file in the underlying OS.
A thread on how to do so can be found here.
I have read the link enclosed, and it's mentioned edit the following file:
/opt/CSCOlumos/conf/syslog_sev_filter.xml file
this is made into the shell using a Prime Infrastructure Virtual Appliance, this is valid for physical appliance too?
I don't have a physical appliance on hand to verify it personally but the underlying file system and directory structure (within /opt/CSCO anyway) should be identical.
In both cases it's the same application running within ADE-OS on a customized RHEL distribution.
I would be doing this soon and report you back. I have another question, PI is capable of monitoring cisco devices power supplies?, I am searching but I haven't found some information about it.
As Marvin also said , this should be applicable to physical appliance too
Thanks-
Afroz
