Bookmark
Subscribe
5566
Prime Infrastructure 2.2 . Backup Issue (Database error)
Hello to every one.
I have an issue with the PI 2.2. When i am trying to backing up the server (application NCS)  i am taking back this error:
NCSELVINF/mpapa# backup PRIMETESTBACKUP repository PRIMEINFRAST.BACKUP application NCS
DO NOT press ^C while the backup is in progress
Aborting backup with a ^C may terminate the backup operation or the backup file may be corrupted
  Backup Started at : 01/28/15 17:25:32
DB size is 99 GB
Available size is 53 GB
you might run out of disk space in repository, Do you want to proceed with backup
do you want to proceed [y/n]?
y
proceeding with backup
ERROR : Cannot proceed with backup as the free space available in oracle fast recovery area (54634 MB) is less than the current database size(60825 MB).
% Internal error: couldn't create backup file
How c an i increase the oracle fast recovery area from PI 2.2 ?
You need more local disk space even though you are using a remote ftp repo. The only exception is when using an NFS share. For ftp/sftp, data during backups are still staged locally.
Have a look at the following from the admin guide: http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-2/administrator/guide/PIAdminBook/backup_restore.html#33033
Regards, Daniel
5 Replies 5
Marvin Rhoads
You selected "y" to proceed after the process alerted that you would likely not have enough space in the configured repository.
I'd try setting up a remote ftp repository on a system with sufficient disk space to accommodate the backup.
hello.
I have already a ftp repository configured where i am trying to take the backup.
  url ftp://10.57.22.212
  user mpapa password hash e5b4b4647ea313bcbee41504a6b9885675927d7e
The hosting of repository location  is staging at my PC (e:) local drive with plenty of capacity
The problem is the database capacity
% Internal error: couldn't create backup file.
There is any way to increase the oracle fast recovery area ? One solution which i already done is to add one HD extra at the vm. But for me, i think that it is  better  solution increasing the fast recovery area , if this is impossible.
Regards, Daniel
Hello Daniel & Marvin
Thanks for the time you spend for me .
My Prime backup is working fine by adding local disk space as i described  and for being sure for the future i configured NFS share.
But I am wandering. Can we configure the Prime 's database ?
I opened a new thread with my problem.
please delete.
