Prime infrastructure 3.2 , non-cisco device monitoring
networkexpert
Dears ,
I am trying to add Brocade switches to cisco Prime infrastructure 3.2
I have verified the provided credential for CLI and SNMP and also I can ping form the switch to Prime .
once added and sync , I received "SNMP Connectivity Failed"
please advise
balaji.bandi
Firstly i would check the model in compatability list.
Seconds, check the SNMP config on broacade side.
If you have windows, download snmplwalk and try config broacade IP make sure you have snmpwalk working with snmp credentials, if all working then try same setting on prime.
or check the Logs why it failing ?
BB
Thanks for your update
please check the attached image , confirmed the SNMP credential  is verified
can you please advise how to check the compatibility?
