Prime infrastructure reports
KacyHicks21882
Is it possible to get PI 3.9 to send a report of the current version of software installed and recommended version?
10 Replies 10
balaji.bandi
PI 3.9 has report capabilites.
we are not sure about this query here ? can you explian more what are you after ?
PI 3.10 released :
https://www.cisco.com/c/en/us/support/cloud-systems-management/prime-infrastructure/products-release-notes-list.html
BB
We are trying to produce a report for our compliance audit that shows we are using the recommended version of software on the devices.
as i read the report show the device has right IOS image as per the compliance ? or do you see the issue here ?
check the device matrix : (is that device in the list ?)
https://www.cisco.com/c/en/us/support/cloud-systems-management/prime-infrastructure/products-device-support-tables-list.html
BB
There is no report, I am trying to create one that will include all devices.
yes the devices are in the list.
ok generate report and let us know any issue to assists here.
BB
KacyHicks21882
I am asking how to generate the report.
That user guide says to enable compliance but, I compliance is not located where that guide says it is.
tep 1
Choose Administration > Settings > System Settings, then choose General > Server.
Step 2
Next to Compliance Services, click Enable, then click Save.
Step 3
Restart the application.
BB
its not there
