Privilege 5 access show running-config not working
BrianPersaud
Hi All
I have show running-config working with privPrivilege 5 5 on all of our switches except one particular IOS version.  Wanted to know if anyone encountered this issue as well.  When I do the show run view full the output is blank.
Here is the output of the commands:
switch1#show running-config view full
switch1#
username test5 privilege 5 secret 5 xxxxxxxxxxxxxxxxxxxx
privilege exec level 5 show running-config view full
Switch Ports Model SW Version SW Image Mode
* 1 28 WS-C3650-24PD 16.6.6 CAT3K_CAA-UNIVERSALK9 INSTALL
2 Accepted Solutions
Thanks Balaji for the document.  I was able to find the solution in there and it is now working successfully using show running-config view full command.  The syntax was a bit different:
Device> enable
Device# configure terminal
Device(config)# privilege exec all level 5 show running-config
Device(config)# file privilege 5
Device(config)# privilege configure all level 5 logging
Device(config)# end
19 Replies 19
Device> enable
Device(config)# end
think you
need
file privilege 5
Thank You So Much This Worked Great.
Glad that this thread was very helpful to resolve your issue.
BB
It worked . Thanks
#username test privilege 3 password ****
WARNING: Command has been added to the configuration using a type 0 password. However, recommended to migrate to strong type-6 encryption
#privilege exec level 3 show
#privilege exec level 3 show running-config
#file privilege 3
#privilege exec level 3 show running-config view
#privilege exec level 3 show running-config view full
that is warning only , future version will be depricated.
BB
Device> enable
Device(config)# end
this is working for me but it is not working for "show derived-config", the command is accepted but the output is empty. Any idea?
give more information on what device and IOS code running.
BB
Hi and thank you for your kindly reply.
Here the informations:
Model SW Version
C9200L-48P-4X 17.06.04
C9200L-24P-4X 17.06.04
This is the configuration about the priviledges
file privilege 7
privilege exec level 7 show access-session
privilege exec all level 7 show derived-config
privilege exec level 7 show running-config view full
Thank you
Luca
output empty when you issue  show derived-config (or show run not show that config ?)
BB
this is if the because of priv 7? what is the outcome user has priv 15 ?
BB
