Privilege 5 access show running-config not working
BrianPersaud
Hi All
I have show running-config working with privPrivilege 5 5 on all of our switches except one particular IOS version.  Wanted to know if anyone encountered this issue as well.  When I do the show run view full the output is blank.
Here is the output of the commands:
switch1#show running-config view full
switch1#
username test5 privilege 5 secret 5 xxxxxxxxxxxxxxxxxxxx
privilege exec level 5 show running-config view full
Switch Ports Model SW Version SW Image Mode
* 1 28 WS-C3650-24PD 16.6.6 CAT3K_CAA-UNIVERSALK9 INSTALL
19 Replies 19
With priv15 it works, the output is complete
Sure agreed, need to do some test and get back to you..not so soon for sure.
BB
i face this problem to !
make new post please
MHM
I was facing the same issue myself.  It was the file command that fixed it for me.
This was what I was getting:
But when I ran the file command from a level 15 user it worked after that.
I had to use the file command to make it work.   I was using CAT9K_IOSXE version 17.06.05 on a C9300-48P switch.
