Problem Authentcation CiscoWorks LMS 4.1 with ACS 5.3
Dear
i have a problem authenticating cisco LMS user through ACS 5 whenever tries  to run a DCR Job  verification it fails to telnet , however it used to work with the pervious ACS 4 but after upgrade , it seems to be a problem , and when i tries to login with this specific user with third party terminal it works fine.
here is logg in the ACS monitor
Failure Reason > Authentication Failure Code Lookup
Failure Reason :
13031 TACACS+ authentication request missing user Password
Generated on:March 12, 2013 7:09:37 PM AST
Description
The TACACS+ authentication request did not provide a user Password
Resolution Steps
The  device is sending a TACACS+ authentication request that is missing  information needed by ACS. Check the device to verify that it is working  properly and has up-to-date software
srego4
Level 2
Level 2
LMS 4.0 allowed only ACS (tacacs) authentication - not authorization. You would have to define roles on the LMS server for authorization. With ACS 5 - there really is no support to add in roles (as in ACS 4.0) in the ACS server. I may not be stating this exactly right, but LMS 4.X broke the integration with ACS ... someone else maybe able to give a better explanation.
I'm running the latest version of both, and it's running fine for me.  You may have to change your TacacsPromts.ini file to include the right prompts.  I think it's:
[TELNET]
USERNAME_PROMPT=
PASSWORD_PROMPT=
You'll have to put in your own prompts, though.   Whatever your prompts are, is what goes afterward.
If my prompt is Myspecialprompt: and pass is Myspecialpassword:, I'd use
[TELNET]
USERNAME_PROMPT=Myspecialprompt:
PASSWORD_PROMPT=Myspecialpassword:
If you have more devices with different prompts, just use a comma after the colon.  Btw, you don't need the credentials in there, just the custom prompts.
