Problem with NTP setting on Cisco-Nexus3064
serzh-gaziev
Hi everyone. I have a problem with ntp settings on this device:
version 7.0(3)I7(6) Bios:version 4.5.0
ntp server 192.168.1.14 use-vrf default
ntp source-interface Vlan2020
clock format 24-hours
ntp access-group serve ntp-server
ntp access-group serve-only ntp-server
ntp access-group query-only query-ntp-acl
feature ntp
no ntp allow private
no ntp allow control
no ntp passive
IP access list ntp-server
10 permit ip 192.168.1.14/32 any
IP access list query-ntp-acl
That`s all settings about ntp.
show ntp peer-status:
Total peers : 1
* - selected for sync, + - peer mode(active),
- - peer mode(passive), = - polled in client mode
remote local st poll reach delay vrf
=192.168.1.14 192.168.1.27 16 64 0 0.00000 default
Stratum is 16 and ntp isn`t working.
But on other device with version 7.0(3)I4(6) that`s all settings are working.
6 Replies 6
Mark Elsen
 - Could be a bug as in : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvd00648
   The latter not your specific platform, but as a test I would remove all access-directives on the ntp settings ,and start by defining a bare-ntp server (only). Check what happens then.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
When i delete these 3-lines, that is all work:
Is there mistake?
what you mean by this, so your NTP Server work as expected ?
where is this ACL applied ? do you have ACL incoming and out going example for NTP
example :
access-list 101 permit udp any any eq 123
access-list 101 permit udp any eq 123 any
BB
i have these mistake in logging:
%VSHD-2-VSHD_SYSLOG_EOL_ERR: EOL function ntp_cli_config from library libntpwd.so exited due to Signal 11
on IOS devices, it used to be that sometimes you would have to manually set the clock initially, to something very close to the actual time, which would then make the device synchronize, you could try the same on the Nexus:
NX3064(config)# clock set 08:43:00 15 sep 2021 <-- make sure that what you enter is close to the real time...
Thank you for your advice. But NTP not working. I set the device:
clock protocol none
clock set 09:48:00 15 sep 2021
clock protocol ntp
exit
ntp sync-retry
