procedure of putting MIB in cisco switches !!!!!!!!
ahsan khan
I want to generate below traps and for that i need to put a particular mib RADIUS-AUTH-CLIENT-MIB on the switch. Can anyone tell me the procedure of putting mib directly on cisco switch.
RADIUS: Received from id 1645/167 10.1.10.6:1812, Access-Reject, len 44
Ahsan Khan.
Martin Ermel
it is not possible to compile or "put" a MIB file into a Cisco switch.
The supported MIBs are compiled within the IOS. Have a look here to see which IOS supports which MIBs:
http://tools.cisco.com/ITDIT/MIBS/MainServlet
http://tools.cisco.com/ITDIT/MIBS/servlet/index
lo.mueller
Hi Ahsan,
make sure to correctly understand how SNMP works.
- A SNMP-Agent (e.g. located on a Cisco switch) is able to send SNMP-Traps being configured.
  (Available traps are hardcoded in the agent)
- A MIB is simply a (virtual) description of available variables and traps
- Each Agent has its own set of supported MIB-Variables ( use #show snmp mib for getting an
  overview of supported Vars on that switch)
  Please have a look at MIB Navigator on cisco.com (http://tools.cisco.com/ITDIT/MIBS/MainServlet )
- You primary 'install' MIBs on the SNMP-Manager getting access to the hardcoded SNMP-Variables
   and to display SNMP-Agent-Traps correctly
Hope this helps
Lothar
