Process DeviceDiscovery Fail to run
rherve
I install LMS 2.5 on a windows 2003
I install all SP2 for CS, CM, RME, DFM.
After the Install, the server works fine.
I run an discovery device this morning an LMS discovery state are in Running state since 5 hours.
I reboot the server an after reboot it the discovery is always in dicovery state. Why? ?
The device discovery process, are in stop state.
I restart it, but this process is in state "Run fail" with an error message find next.
DeviceDiscovery Failed to run 0 -2 1073741822 N/A 30/11/2005 15:17:00
Have you any answer about this problem?
I reboot the server again, an I have the same problem
Please help!!!
Hervé
nhabib
Level 9
Level 9
You may be running into CSCsb21408:
LMS 2.5 Device Discovery remains stuck - does not go to Idle
I have open a case and I receive the fix patch
