Bookmark
Subscribe
941
RME Software distribution
p-lees
I have LMS 3.2 with RME 4.3.1.
I am currently managing approx 30 Nexus 5010's and 5020's. I want to use the software distribution feature within RME, however when i go to the device selector within software mgmt > software distribution > by device - the majority of the devices are greyed out including all of the N5K's. The only devices that are not greyed out are an ACE module and a couple of 3750's. Even 3945 routers are greyed out.
Does anyone know what the problem is here ? - i have a successful archive and inventory of all devices and can make changes using netconfig etc ..
Any advice gratefully received
Phil
Michel Hegeraat
Level 7
Level 7
I don't have such devices myself, but I think you may want to check the "supported devices table" to see if software distribution is supported on these devices and or if you need to patch/upgrade RME
http://tools.cisco.com/search/JSP/search-results.get?strQueryText=supported+device+table
There you see that an update for RME is required for nexus.
Cheers,
Michel
Michel Hegeraat
Level 7
Level 7
Cheers,
Michel
That did the trick !!
Many thanks
