12-25-2020 07:30 AM
I have a strange problem , i have connection between 2 switches 9200L and 3750X with SFP GLC-LH-SMD
and on the 9200L side shows Connected and on the other side (3750x) shows Not connected
Solved! Go to Solution.
12-25-2020 10:21 AM
how is these connected direct patch cable ? or you have a provider involved to connect?
GLC-LH-SMD (what kind of patch cable or cable you using to connect both ?)
post below output both the side
show run interface gi x/x
show interface gi x/x
suggest try no negotiation should work
12-25-2020 08:57 AM
- Make the connection again, and then check the logs on both platforms ,see if you can find anything useful
M.
12-25-2020 10:21 AM
12-26-2020 02:49 AM
no negotiation on both switches worked for me thank you very much
12-25-2020 04:13 PM
Connected on one side but "not connected" on the other?
I have seen this before.
Test and make sure the entire length is not broken. The description described is due to one of the fibre pair is broke.
12-26-2020 01:15 AM
@Leo Laohoo i agree here, since you getting circuit loop you also see one side UP/UP.
