SG 350 configuration guidance
kick534
Hi team,
we purchase sg350 52P Switch , we will connect it to internet modem ( from modem DHCP is enabled so without any configuration we will get internet) range such as 192.168.1.1 to 192.168.1.254.
but i want to create vlans such as ( users, cameras, voice, cctv) and configure inter vlan routing so each vlan can communicate each other,
user network : 172.168.25.0/24
cameras : 172.168.26.0/24
voice : 172.168.27.0/24
cctv: 172.168.28.0/24
Please advice  how to configure the switch port which is connect to internet modem.
or i need routing to configure ????
23 Replies 23
Please advise ISR4221/k9 it will solve my issues
intervlan routing and Layer3/routing/NAT features.
@ Tyson Joachims
Question-1 :
i want to configure Voice and Data on a single port.
for example my data vlan -10 and voice vlan -11
.i configured the below configuration in switch sg-350 but when i make show run it show only (config-if-range)#switchport trunk allowed vlan add 10 and data vlan ip not taken in int gi port config
please provide the correct steps :
(config)#voice vlan id 11
(config)#voice vlan state auto-enabled
(config)#interface gi 1
(config-if-range)#switchport trunk native vlan 11
Question 2: if i configured both data vlan and voice in single port and want to use only laptop or PC it will work or i need to connect compulsory to phone.
Question 3: i want to remove the below macro configuration ( please provide a command for port factory reset as new)
interface GigabitEthernet6
spanning-tree portfast
switchport access vlan 12
no macro auto smartport
Question 4 : Same here i want to remove the all the configuration ( factory reset port as new)
interface GigabitEthernet17
spanning-tree link-type point-to-point
switchport mode trunk
macro description switch
!next command is internal.
macro auto smartport dynamic_type switch
Thank you for your support
1. Depending on the phones that you use will determine if the bellow configuration will work but I typically use the following commands for the switch interfaces:
interface range GigabitEthernet1-24
 switchport mode access
 switchport access vlan 10
 switchport voice vlan 11
2. Yet again this is dependent on the phone. If it is a Cisco phone then the phone will know that the voice VLAN is 11 via CDP from the switch and then any computer plugged into the phone will get VLAN 10.
3. On an SG350, I believe the commands you will need to remove the configuration that you showed will be:
 no spanning-tree portfast
I'm still not a fan of the macros so I'd leave it as "no macro auto smartport" but that's up to you.
4. I believe the commands to return the following port to defaults would be
 no spanning-tre link-type point-to-point
Thank you for your support ( Just to confirm before going to customer site )
below commands will support in SG350 series Switch
That is correct. I'd also add the command "no macro auto smartport" as well. The smartport seems to me to be more trouble than it's worth and tends to make changes that I don't want it to make. You may prefer to use them so I'm just offering my opinion.
@TJ-20933766
i try to configure the Voice Vlan in SG-350 series switch below error :
Mfa-Sw2(config-if)#sw
Mfa-Sw2(config-if)#switchport voi
Mfa-Sw2(config-if)#switchport voice vlan 11
% Wrong number of parameters or invalid range, size or characters entered
Mfa-Sw2(config-if)#
Please provide me the correct command for CLI.
So it appears as though I gave you some bad advice. I did some searching and found this article:https://community.cisco.com/t5/small-business-switches/sg350-28p-voice-and-data-vlan-config-on-a-single-port/td-p/4008018
it appears that to add a Voice VLAN, you will actually want the following commands:
(config)#voice vlan id 100
(config)#interface fa1   <--change the interface or range depends on the requirement
(config-if-range)#switchport trunk native vlan 101
(config-if-range)#switchport trunk allowed vlan add 100
Sorry about that.
@TJ-20933766
Thank you for your support,
Can you please confirm the below configuration is correct, Suppose My Data vlan is 10 and Voice vlan is 11
(config)#interface Gi 1
(config-if-range)#switchport trunk allowed vlan add 11
 here Native vlan will be Data Vlan ???
correct
