SNMP Cisco C1300 – No CPU, Memory, or Temperature
Yivgeny
Hi everyone,
I recently deployed a new Cisco Catalyst C1300 switch and configured SNMP monitoring (SNMPv2c) using PRTG. I’m able to successfully monitor:
  • Interface traffic
  • Device uptime
However, I’m unable to retrieve data for CPU usage, memory utilization, or temperature sensors. I’ve tried using SNMP walk tools but couldn’t find relevant OIDs returning values for these metrics.
My questions:
  1. Does the Cisco C1300 series support SNMP monitoring for system health (CPU, memory, temperature)?
  2. If yes, which MIBs or OIDs should I use?
  3. Are there any configuration steps I might be missing to expose those metrics via SNMP?
Any help would be greatly appreciated. Thanks in advance!
marce1000
     - @Yivgeny  >...Does the Cisco C1300 series support SNMP monitoring for system health (CPU, memory, temperature)
                             I doubt it , because these devices are small business oriented, for temperature , you could try
                             to snmpwalk the CISCO-ENVMON-MIB  (https://oidref.com/1.3.6.1.4.1.9.9.13.1.3)
      Cisco MIBS these days can be found at : https://github.com/cisco/cisco-mibs
  M.
Thank you for your answer, it's not working.
Found this article - https://www.cisco.com/c/en/us/support/docs/smb/switches/Cisco-Business-Switching/kmgmt3636-snmpv3-common-oids-cbs350.pdf
Base on this article can monitor cpu during last munute/second. Looking how to monitor Temperature and memory also.
Any advice ?
Wei Ting Lin
Is there any solution to this problem? I have the same problem....
