SNMP log need Filtering
ManivannanR3953
Hi All,
     We have two vendor one who maintain entire network equipment's, Another vendor taking bandwidth part, Our concern is that interface Fa0/1 up/down status alone send via SNMP to Bandwidth vendor's monitoring server,
    Other information like CPU / Memory usage, configuration, log are not required to send via SNMP to Bandwidth vendor
kindly suggest us how to procced for this.
marce1000
 - FYI : https://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/13506-snmp-traps.html
 You may want to look at this particular example : (see below-in-frame) , you may just adapt it to your needs , presumably as in
   snmp-server host vender-snmp-server-addr public linkup linkdown  (exact syntax may vary but easily can be found when listing all traps)
snmp-server host 10.10.10.10 public config bgp tty
snmp-server enable traps config
snmp-server enable traps bgp
