snmp oids for the command "show counters interface intx/y delta"
ROMAN TOMASEK
I have a question about SNMP OIDs for the command "show counters interface intx/y delta" on Catalyst6500. The customer wants to create graphs for the following values:Overruns, qos0Outlost, InErrors, OutErrors, InDiscards, OutDiscards etc..
Is possible to get these values using SNMP??
Thank you
Roman
Dan Frey
These OIDs can be found in the IF-MIB located here:
ftp://ftp-sj.cisco.com/pub/mibs/oid/IF-MIB.oid
Dan
Thank you, Dan. These OIDs are for the output from the command "show interface int x/y". But I think, that these OIDs are not for the command "show interface int x/y delta".
Roman
I am very interested in this also... especially the qos0Outlost value!
John
