SNMP trap messages
jeanSamarani_2
Dear Support,
We are getting a huge amount of messages  on our Monitoring system from our 3750 switch. Can you please advise what's wrong?
Tue  Dec 07 09:20:00 Got 271 byte SNMP Trap from:  10.160.124.166
Tue  Dec 07 09:20:01 Got 273 byte SNMP Trap from:  10.160.124.166
Tue  Dec 07 09:20:04 Got 273 byte SNMP Trap from:  10.160.124.166
Tue  Dec 07 09:20:06 Got 273 byte SNMP Trap from:  10.160.124.166
Tue  Dec 07 09:20:17 Got 273 byte SNMP Trap from:  10.160.124.166
Tue  Dec 07 09:20:17 Got 271 byte SNMP Trap from:  10.160.124.166
Tue  Dec 07 09:20:18 Got 273 byte SNMP Trap from:  10.160.124.166
Tue  Dec 07 09:20:20 Got 273 byte SNMP Trap from:  10.160.124.166
Tue  Dec 07 09:20:28 Got 273 byte SNMP Trap from:  10.160.124.166
Tue  Dec 07 09:20:28 Got 271 byte SNMP Trap from:  10.160.124.166
Tue  Dec 07 09:20:30 Got 273 byte SNMP Trap from:  10.160.124.166
Tue  Dec 07 09:20:31 Got 273 byte SNMP Trap from:  10.160.124.166
thanks
Can you post the details/ contents of this trap?
10 Replies 10
How can I do that ? Could you pls advise?
thanks a lot !
Your monitoring system should also tell you what the contents of the traps are.
If you cant then
1) get a wireshark capture
2) enable "debug snmp packets" only for a short while and get the contents of the trap
Brahadesh
Below the OID. Hope this clarify the content of the trap. Any idea what could be the problem?
Wed  Dec 08 08:45:28 event type:.1.3.6.1.4.1.9.9.41.2.0.1,oid  length:12,specificType:1
clogMessageGenerated
Appreciate your help guys !
Jean
The above OID translates to clogMessageGenerated meaning for which is
When a syslog message is generated by the device a clogMessageGenerated notification is sent. The sending of these notifications can be enabled/disabled
via the clogNotificationsEnabled object."
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=1.3.6.1.4.1.9.9.41.2.0.1&translate=Translate&submitValue=SUBMIT
Like the above description says you can disable by setting the value for clogNotificationsEnabled as false.
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=.1.3.6.1.4.1.9.9.41.1.1.2+&translate=Translate&submitValue=SUBMIT&submitClicked=true
Brahadesh
Thanks Brahadesh for your prompt response.
How can i disable sending these notifications ? Is it something that could be done from the switch?
what are the commands?
Thank you again for your help.
This has to be done thorugh SNMP
If you have a tool called Net-SNMP, open source, google it. Download and install it. Use the following syntax from the command prompt
snmpset -v 2c -c 1.3.6.1.4.1.9.9.41.1.1.2 i 2
Brahadesh
OK will do. I assume once done this will disable the switch from sending these notifications.
Thanks again from you support. I will let you know if I face any issues.
That usually means your 3750 has "snmp-server traps syslog" configured, so every "logging history" entry is being sent as a trap to your SNMP server.
To stop the flood, simply configure "no snmp-server traps syslog" on the device.
Agree. That would do the trick too
Brahadesh
