SNMP Traps caused by syslog ivents
Leonid Voronkin
Hello, colleagues.
How to make the cisco send SNMP Trap when syslog ivent (for example %IP-4-DUPADDR: Duplicate address) occurred?
________________________________________________________
Если ответ понравился, ставь звёздочку. Если ответ помог решить твою проблему, утверди его в качестве решения
Thanks. If you are talking about the same thing, Balaji.bandi says please look at my additional question.
balaji.bandi
Try - snmp-server enable traps syslog
BB
It is a variant. But if use this command all syslog messages will send as traps. May be is it possible to make custom trap for only one event?
