SNMPv3 Context
hmc2500
If you configure context on a cisco device like the below  line. What should the context name be on the snmp server host?
snmp-server group v3group v3 auth context vlan- match prefix
balaji.bandi
you are matching the context vlan-
context vlan-(vlanid)
BB
I understand this "context vlan- match prefix" means match any vlan id on the switch. The switches could have different vlan id's. How could you match all vlans with the context name on the server?
that is not an authentication mechanism, you need to configure NMS as per the screen example :
BB
