SNMPv3 on NX-OS
kelvinpoh
Hi all,
I am facing issue with configuring SNMPv3 on NX-OS.
Can anyone guide me on the configuration steps from IOS to NX-OS for snmpv3 configuration:
snmp-server group NMS v3 auth read v1default access 55
snmp-server user NMS NMS v3 auth md5 a1b2c3 priv aes 128 d4e5f6
Thanks.
Kelvin
Michel Hegeraat
Level 7
Level 7
Not really, .....
NX-OS appears not to support groups, except the build in ones admin, network-operator
I don't think you can associate snmp v3 with an ACL
For the rest you can work your way through the commands using the ? to see what options are available.
this will work:
snmp-server user NMS network-operator auth md5 a1b2c3  priv aes-128 d4e5f6
this will give you read access, group admin gives read-write
Cheers,
Michel
