SSH authentication failure CiscoWorks LMS 4
Colin Higgins
Level 2
Level 2
I am trying to get CiscoWorks LMS 4.0 to connect to my routers in order to back up configurations, but I am getting SSH authentication failures reported in the router logs (and archiving fails).
The credentials LMS is using is a username and password with priviledge 15: the account is established in TACACS+. I can log into the devices directly with this user account.
However, I cannot TFTP from the routers to the LMS either (I get a permission denied message in the router).
LMS did manage to fetch some configs, but 90% of my devices are having this issue.
Any advice would be great
2 Accepted Solutions
Michel Hegeraat
Level 7
Level 7
Can you login on some of the failing devices from the server itself, rather than from your pc? You can safely install putty or other ssh clients on the server.
Have you tried to validate the credentails in the DCR?
It is 'normal' to get a permision denied when you do a tftp to LMS. The filename must exist in the CSCOpx\tftpboot\ directory with permission to write for casuser.
Cheers,
Michel
Hi Colin,
     How do you fix it?! My client's 90% devices cannot get the configuration by lms, just like your situation.
Michel Hegeraat
Level 7
Level 7
Cheers,
Michel
It eventually corrected itself--thanks
Hi Colin,
For some reason the intiial credential set did not take--the system was trying to use default settings. I went back in and set everything back up for SSH.
It is fetching 90% of the configs--I still have some issues with some of them. I cannot directly TFTP from a device to CiscoWorks, but it seems to be able to fetch the configs automatically.
tira: are you using TACACS+ for authentication?
