From RME you can compare startup and running configs from - RME > Config Mgmt > Compare Configs (I'm not at work now but think that's correct). Once you get to this point in the browser, you can compare startup/running, 2 versions and a couple of more things. I don't remember exactly what the choices are but I'm pretty sure there are 4 choices on that screen.
Anyway, you can compare the startup to running configs but are limited to one device at a time using this method. Somehow I would like to batch this process to run against a lot of devices. If I knew the script that gets kicked off, I think I could somehow batch it up.
Help!!!
Thank you, Rob
