03-17-2006 06:14 PM
Could I somehow automate the running of this report on RME 3.5?
Solved! Go to Solution.
03-20-2006 06:57 PM
Unfortunately that functionality does not exist.
You may write a script to use the diff command for comparing the *running.cfg and *startup.cfg in the following directories:
/var/adm/CSCOpx/files/archive/config/
03-20-2006 06:57 PM
03-21-2006 05:02 AM
That would be a very nice feature!
However, my scripting skills are weak and I'm not worth a darned with the diff command!!
03-28-2006 08:48 AM
What about for RME 4.0 for Windows? This would be super helpful...
