switching and routing
ghassen6121996
Hi guys, I'm trying to connect 3 networks using 1 one router 1841.
Is the use of the 2 network, LAN port and for the third one WAN port
The first network is  4 PC connected through switch which is connected to the router by interface vlan 9.
The second network is connected through another switch which is connected to the router by interface vlan 8.
My main objective is to ping the volume 9 and 8 to the third network..
but is not happening
there is my router configuration  :
interface FastEthernet0/0
ip address 10.22.143.70 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet0/0/0
switchport access vlan 9
switchport mode access
switchport nonegotiate
interface FastEthernet0/0/1
switchport access vlan 8
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
no ip address
shutdown
interface Vlan8
ip address 10.10.8.1 255.255.255.0
interface Vlan9
ip address 10.10.9.1 255.255.255.0
ip classless
ip route 10.22.143.0 255.255.255.0 FastEthernet0/0
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
switcher 1 with vlan 9 :
spanning-tree mode pvst
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan9
mac-address 000a.f39d.d9c9
ip address 10.10.9.11 255.255.255.0
ip default-gateway 10.10.9.1
line con 0
line vty 0 4
login
line vty 5 15
switch 2 vlan 8
interface Vlan1
no ip address
shutdown
interface Vlan8
mac-address 0005.5e69.e610
ip address 10.10.8.11 255.255.255.0
ip default-gateway 10.10.8.1
third newtrok that i like to ping
if you want to block traffic between Vlan 8 and Vlan 9, you need this:
access-list 101 deny ip 10.10.8.0 0.0.0.255 10.10.9.0 0.0.0.255
access-list 101 permit ip 10.10.8.0 0.0.0.255 any
interface Vlan8
ip access-group 101 in
With one router, indeed you do not need any routing (static or dynamic).
11 Replies 11
balaji.bandi
Do you have network diagram how these connected also is this lab or real kit ?
BB
this is a lab i will upload it now
i want to ping the sw 10.22.143.0 255.255.255.0 from vlan 8 and vlan 9
if this is a Packet Tracer  project, post your zipped project (.pkt) file...
hi my brothers
this is a lab
and u can extract this file
i dont know why but the vlan 8 ping vlan 9
and it should ping the third network 10.22.143.0 255.255.255.0
I can ping e.g. 10.22.143.43 from anywhere in Vlan 8 and 9. What source and destination IP addresses exactly can you not reach ? From where (source IP) to where (destination IP) can you not oing ?
Hi yeah
yeah i was wrong my because i thought that i changed the default gateway .
the problem with my project is if u remove the static route (ip route x.x.x.x ...) from the router u will still reach the 10.22.143.0 netwrok why ?
try it by your self if u want how we can ping the third  newtork without routing
the second problem that i can ping beetween VLAN 8 and 9 but in the normal case this is not right the 2 vlan should not communicate .
why the vlan 8 and 9 can communicate
you have three directly connected networks, they will communicate without any routing (static or dynamic). Why should both Vlans not be able to communicate ? There is nothing (e.g. access list) blocking the traffic...
Mr georg i know that i'm a beginner man with routing and switching so i will ask you some question..
if want to make the vlan 8 cannot ping vlan 9 ? what i should do ? use access list and deny???
and when i use the routing just when i have more than one router ? so here i don't need routing ?
interface Vlan8
Thaank u very much
