Switching From Class C Network to Class B Network
rjrahuljain0106
Dear All,
We are thinking of Switching from Class C network to Class B Network, we wish to create 3 VLANs one for Workstations including our wireless network for in house Employees one for R&D and another One for Guest Network, Is it possible to set this up can anybody explain me the setup and configuration required in the network switch and access points or any thing that is required to configure in firewall
Dennis Mink
we sure can, but by the looks of it you dont have a large network. so why the considration going to a class B?
seentially what you need to do, is draw up and what you want to replace it with say, 192.168.100, 192.168.101 etc  or whatever you want to change it into
Please remember to rate useful posts, by clicking on the stars below.
Jaderson Pessoa
How many devices you will connect on each vlan?
Who will be the gateway of network (firewall, router or switch L3).
Jaderson Pessoa
*** Rate All Helpful Responses ***
Mike.Cifelli
Most people would use a secondary SVI address if needing to migrate your vlan and/or expand your range. Using secondary IP addresses allows you to have two logical subnets using one physical subnet. You can also create one network from subnets that are physically separated by using a secondary address.
HTH!
