01-13-2020 01:50 AM
01-13-2020 02:28 AM
- Do you also have a question ? It would then be really handy to be able to provide you an answer ?
M.
01-13-2020 02:54 AM
01-13-2020 03:57 AM
i'm sorry it did'nt post my questions
hi
i have 3850-48xs-s that configured as stackwise
and i conncet him with two interface 10g to 3850-12xs-s
the two switches configured as L2 switches
i dont want to use lacp between them
i have two questions
1.i want to use switch port backup (but the command is not support)
when the one interface is down or vlan and mac address will come from the second interface
what the command is to do so?
2.there is command that if i stop get the mac address from the first interface(and the interface link is up)
it will be come from the second interface?
something like monitor the interface or the mac address that i decide to force the action?
regards
01-13-2020 04:35 AM
01-13-2020 05:50 AM
it's ok
but i have something between them
(its transparent to the switches)
and i want if the the device that connect them but i have still link
its go to the back up even in the interface will be still up
i mean the mac address need to go from the backup interface
01-13-2020 06:18 AM
