08-08-2011 02:11 AM
Hey,
I would like to backup the config of all devices but I have an error whan I launch the Sync Archive.
See the error below:
The following is the status of your Sync Archive job:
Job ID : 1637
Status : Job Failed(1)
Description : test sync
Details : http://ciscolms.domain.local:1741/rme/DcmaJobDetails.do?jobid=1637
Start Date and Time : Mon Aug 08 11:02:14 CEST 2011
End Date and Time : Mon Aug 08 11:03:23 CEST 2011
RME Server Name/IP : ciscolms.domain.local
Execution Summary
Pending : 0
NotAttempted : 0
Successful : 0
Failed : 1
Partial Success : 0
I don't know if I forgot something, could you please help me?
Kind regards,
Sébastien
08-11-2011 08:24 AM
Hi Afroj,
When I had problems at the begining, I saw on the forum that somebody had the same problems. So he modified the file TacasPrompts.ini like that :
[TELNET]
USERNAME_PROMPT=Username:,username:,login:
PASSWORD_PROMPT=Password:,password:,passwd:
I modified my file like the same way.
Thanks.
08-11-2011 09:23 AM
Hi Seb,
you are right that what we need to configure in your case :
[TELNET]
USERNAME_PROMPT=login:
I hope the jobs are running file after this..
Afroj
08-12-2011 01:30 AM
Hi Afroj,
I always have the same error with job failed(1). What can we check?
Thanks.
08-12-2011 02:10 AM
Hi seb,
Enable the debugging for Archive Management and device Management under RME >admin>system prefreneces >Application log level settings
--Ran a Sync Archive and CDA job for the problematic device
--Once the job is finished send me the cda.log ,EssentialDM_server.log and dcmaservice.log and job folders
Afroj
è schedule a Sync Archive and CDA job for the problematic device and trigger packet capture. And get us the following:
· Packet capture for both Sync Archive and CDA Job
· Screenshot of the device login prompts (When Connected via TELNET)
· Try to connect the device via Telnet from the LMS server and update us, whether able to TELNET to the device from the LMS server
08-12-2011 04:58 AM
08-30-2011 12:32 AM
Hi Afroj,
Did you have a look to my log files?
Thanks.
08-31-2011 07:51 AM
Afroj,
Did you check my files? Could you please help me?
Thanks.
08-31-2011 12:44 PM
Hi seb,
Did you ran the device credentilas verification job for this device :192.168.254.111
what is the status of the CDA job.?
If CDA job still says No Value to test then first check the device credentilas fot this device by Exporting in a text file ( Common service >device mgmt ) and verify that the credentials are correct..
If the Exported credentilas are correct then send me the TACACSPROMPTS.ini file..
Afroj
09-01-2011 06:05 AM
This is the result of the CDA job.
Could you please tell me where I have to go to export the device credentials. You wrote common service -> device mgmt, how I have to go there?
Thanks.
09-01-2011 07:11 AM
09-01-2011 07:32 AM
Thank you Afroj, but I have LMS 4.0 I haven't the same menu...
09-01-2011 07:54 AM
Hi ,
My Bad.. I forgot ..
In lms 4.0 :
Go to : Inventory > Device Administration > Add / Import / Manage Devices
Afroj
09-01-2011 08:04 AM
I found it Afroj!
This is the file generated by the export.
There is no credentials, it is normal?
My TacacsPrompts.ini file :
[TELNET]
Thanks.
09-01-2011 09:04 AM
Hi Seb,
It means you have not defined any TELNET\SSH credentilas.. Please add the Right credentilas and I hope that will take care of the issue..
Afroj
09-02-2011 01:16 AM
Hi Afroj,
I edited the credentials for all my devices in the Add / Import / Manage Devices but the synchronization doesn't work for all of them. It worked for 3 devices, I have an error for others.
Have you an idea?
Thanks.
